![]() | Home > Technical (L322) > Splash Screen - On Too Long? |
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 ![]() ![]() ![]() |
My RR does this also Shaun - don't know why |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6381 ![]() ![]() |
Once you have unlocked the car you are waking up all the systems in readiness to drive away. After locking these systems will slowly shut down in sequence taking a total of about 18 minutes until there is no longer a drain on the battery. Discovery 4 HSE
There's your answer Shaun - now we both know.
If you want to test how long yours takes to switch off just pop the bonnet and 'fool' the bonnet open/light switch, then plug an ammeter into the battery, switch off and watch the amps slowly decreasing. Shouldn't take more than 20 minutes total.
Shaun Member Since: 02 Jul 2010 Location: Hull Posts: 58 ![]() ![]() ![]() |
Thanks for the reply, nice to know that its all OK. |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
Also when I had my first L322, and the 2 Sports the dealers have always recommended lowering the suspension to access mode if leaving the car for a while as this also tells the ECU's that you might not be returning for a long time and it puts everything into sleep mode sooner 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
