Home > Technical (L322) > Gearbox
Swiftman
Scotland 2006 Range Rover Vogue SE Td6 Zermatt Silver
Gearbox
Set of on holiday this morning with caravan in tow. traveled 55 miles BANG. No drive & horrid noises coming from gearbox even when out of gear Had to get car & caravan recovered looks like a new gearbox required holiday cancelled for now . Any advice for gearbox repairs in Central Scotland ." Just turned 81000 2006 model Big Cry Big Cry
Post #264068 8th Jun 2014 9:41pm
RRPhil
Presumably your TD6 has had the front propshaft/differential upgrade?
Phil
Post #264077 8th Jun 2014 10:46pm
Swiftman
Gearbox
Thanks for quick reply but have checked prop shafts when in gear they are not turning & noise is present when out of gear
Post #264104 9th Jun 2014 7:45am
You have a pm Thumbs Up
Post #264107 9th Jun 2014 8:04am
Swiftman
Gearbox
Thank you for advice every one told me same place booked in for tomorrow thank you
Post #264255 9th Jun 2014 8:22pm
iphs
England 2003 Range Rover Vogue Td6 Buckingham Blue
Phil
What upgrade would that be and how would I know if my TD6 has had it done?
Post #264256 9th Jun 2014 8:25pm
Swiftman
Gearbox
Garage phoned today gearbox & transfer box required Big Cry
Post #264734 11th Jun 2014 7:50pm
Swiftman
New gearbox
Collecting car on Monday refurbished gearbox , torque converter & transfer box all fitted . If any money left will carry on with holiday Bow down
Post #265296 13th Jun 2014 9:04pm
Swiftman
New gearbox
Got car back Monday Thumbs Up From Mackie. Transmitions. In glasgow Gearbox / transfer box / torque converter / oil cooler al replaced feels like a new car very smooth gear change . First class service. From this company + 3year warranty on parts . Holiday starts tomorrow .
Post #265820 17th Jun 2014 5:57am
ebajema
Sorry to hear it was a costly repair but glad you are on the move again !! MY 2010 5.0 SC Galway green and sand interior!!
Post #265821 17th Jun 2014 6:26am
Bob the B
United Kingdom 2004 Range Rover Vogue Td6 Santorini Black
Hi.
Just had exactly the same problem as Swiftman Big Cry
Pull out from a junction, big bang/thud and no drive.
Got recovered to a Land Rover service centre, thinking it was the faulty front propshaft/differential only to be told its already had the upgrade to the new one.
The spline gear between the gear box and transfer box has worn. As Land Rover don’t sell the shaft separately I’ve been told a new gear box and transfer box are needed for a total of £6000 fitted Shocked Censored
My main question is with the weak diff being replace for the new type has this moved the problem to a different area ie the output shaft of the gear box which causes the spline gears to wear?
My car is a MY04 td6 with 145k on the clock.
Post #283416 28th Sep 2014 9:03pm
RRPhil
I’ve heard of that happening on the 6 speeds (when the spline isn’t greased with the special anti-seize paste) but never before on a 5-speed.
I’ve got a spare transmission output shaft and transfer box input shaft if you’re stuck.
Phil
Post #283432 28th Sep 2014 9:32pm
Bob the B
Thanks Phil but its (hopefully) getting sorted.
The garage has sent the gear box off somewhere to get a new shaft put in and should take 7 - 10 days. They have said that Land Rover wont guarantee this fix but hopefully it should only be £2000ish.
I was mainly curious what others thought of this now being a weak point?
Grant
Post #283443 28th Sep 2014 10:25pm
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
how does one find out if it has had the upgrade? was this a recall done by land rover?
Post #283516 29th Sep 2014 11:30am
Bob the B
I've been told the upgrade (was never officially a recall) was stopped last year.
If you do a search on here I'm sure I've seen pics of the old and new diff but I'm sure if you take your car to a land rover dealer they would be able to check as well.
Another option is to ring a dealer and give your vin to them as it should have been recorded if the upgrade was done.
Grant
Post #283574 29th Sep 2014 3:27pm
