![]() | Home > Maintenance & Mods (L322) > Piano black wrap |
B3EEE Member Since: 23 Jul 2013 Location: S Wales Posts: 99 ![]() ![]() |
Piano black, sure looks like good ol' gloss black in photos. Mines Piano black and looks different to yours, or is mine another black, has a slight grain in it. |
If it has a grain to it then yours will be lined oak sir... Look at the link below, does it look like this? http://www.ebay.co.uk/itm/Range-Rover-L322...2c4b9df8b2 |
Ha ! Thats it, limed oak - looks black. I remember now as I couldn't get limed oak to replaced door arm rests so went for Piano black - so mines a hybrid !! |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
If the parts are removable I'd suggest painting them. I only used wrap on the bits I couldn't remove. Is this where I put the car details and a bit about myself ?........ |
Your right Nick as good as the wrap looks I haven't been happy knowing that's it's all wrapped. With that in mind I have been busy removing wrap and am now in the process of painting. I have done a few parts including the panel above the upper glovebox all in gloss black with 8 coats of lacquer. I have to say its looks factory with a real mirror finish. It's a lot of work but worth it and I always like to have a little project on the FF. Pictures to follow once completed |
Conor...your a b |
You open glove box remove left vent and you will see it is held in by a single screw remove that and then pull out towards you held in by two clips. I removed the range rover badge and cleaned underneath to remove sticky residue. Don't be tempted to put badge back on until you have fully sprayed panel sanded and compounded and polished Otherwise polish gets under badge ask me how I know |
Please see my last post.....
Mmm well after your advice i did the front ashtray. For a simple piece if trim it was a nightmare as i was over confident. I have had to do it twice and although it looks good im still not happy with it. Lacquer needs at least 36 hours before sanding. The journey continues |
Update....upper glove box panel done, gave the RR badge a tickle of sparkle silver and laquer too...
Mines still work in progress have been busy at work so Rangey has taken a back seat.Any pics Nick promise i will have mine soon |
