Home > In Car Electronics (L322) > Range Rover 10 pin to BMW 6 and 3 pin CD Changer Harness
alahmed
Saudi Arabia 2004 Range Rover HSE 4.4 V8 Bournville
Hello
I need Help please.
i have decided to replace my OEM CD Changer with Grom.
as i know my 2004 HSE Range Rover comes with 10 pins CD Changer cable.
Now to be able to install and use Grom and the a converter harness which is converting Range Rover 10 pin to BMW 6 & 3 pin.
it should be similar to this harness cable on the next link
http://www.the75andztclub.co.uk/forum/imag...94deac.jpg
the question is : where can i find the required harness?
thank you in advanced for any help.
Post #194464 15th Jun 2013 5:40pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
Go to a local scrapyard, dig about in the back of a 3 series BMW (2000 to 2005 ish), behind the panel on the left hand side of the boot and you'll find the cable with the 6 pin and 3 pin connectors. A pair of pliers and a couple of quid to the owner and you'll have what you need. Ten minutes to repin and Robert is married to your Aunt.
Chris
Post #194527 16th Jun 2013 9:25am
alahmed
Thank you Chris
i will do that.
Post #194609 16th Jun 2013 8:00pm
alahmed
Hi
could anyone help me to know the correct order of the 3 and the 6 pin connectors?
i want to move the cables from the 10 pin OEM Cd changer connector to the 3 and the 6 pin connectors and then connect Grom Audio unit.
So
Based on the image i have attached above
what is the correct order:
The 3 pin connector , is it A or B?
The 6 pin connecter , i have marked each hole with a Letter from A to F , so could you connect each letter with a number from 1 to 6 , to identify its correct order.
Thank you in advanced for any given help.[/img]
Post #205190 22nd Aug 2013 6:50am
chris_read
From memory I think that if you look closely there are numbers on the connectors beside the holes you put the pins into. But I may be wrong.
Post #205322 23rd Aug 2013 8:30am
alahmed
Dear Chris
Regarding the 6 pin connector , You are right the 6 small holes are numbered , but because i am not sure of the connector i received is the correct one and if the holes order the required order , i was looking for a another confirmation as i do not want to damage the Grom unit.
Regarding the 3 pin connector there is no numbers at all which is confusing me because i do not where to start.
A = from left to Right
B= from right to left
below is the BMW cable i received , and i hope this could help
Post #205384 23rd Aug 2013 5:13pm
chris_read
Ok - I've had a look at mine and for the 3 pin plug the terminals go 1 2 3 in the direction of your red graphic - A.
Good luck!
Post #205386 23rd Aug 2013 5:29pm
chris_read
And on your 6 pin diagram the numbers and your letters correspond as:
A-1
B-2
C-3
D-4
E-5
F-6
Again - hope all goes ok!
Post #205388 23rd Aug 2013 5:36pm
alahmed
Thank you so much Chris for your kindness and for your great help.
i will move the required cables from 10 pin plug to 3&6 pin plugs and then connect the Grom audio unit and update you with the result ASAP.
Post #205389 23rd Aug 2013 5:54pm
Sami Saeed
Saudi Arabia 2004 Range Rover HSE 4.4 V8 Baltic Blue
Hi Alahmas .. Hope you are fine & doing well .. I'm wondering if you already installed the Grom adapter and it is functional properly ?? As I'm willing to use mini ipad rather than the outdated RR head unite .. Thx in advance & Best regards
Post #264560 10th Jun 2014 11:00pm
alahmed
Yes Sami. Its working perfectly .... ( USB stick as a Virtual 6 CDs , and also the Bluetooth music streaming)
you still need the none-touch head unit to control the Grom unit
Post #264562 10th Jun 2014 11:42pm
OyabunG
Australia 2004 Range Rover HSE Td6 Zermatt Silver
Hi, what model Grom unit did you purchase?
Post #264792 12th Jun 2014 2:36am
alahmed
Dear OyabunG
the one i have ordered is GROM-USB2P-BMWT
you will find it on the next link:
http://www.gromaudio.com/store/usb_adapter...r_kit.html
Post #265045 12th Jun 2014 9:57pm
Site Copyright © 2006-2020 Futuranet Ltd & Martin Lewis
