![]() | Home > Wheels & Tyres > New cost effective 20" tyre |
Soft tyre walls are ok if you really want comfort and don't mind risking having to turn sharply in an emergency |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3807 ![]() ![]() |
On the otherhand I have personally ditched part worn tyres with 6mm tread because they were starting to show signs of age, or had been run flat - none of which were obvious. These ended up on the s/h market - they were ditched for a reason, no way would I entertain s/h tyres unless they were on a slow moving tractor... By the time you factor in fitting and balancing and the part worn status of the tyre there is very little cost saving between that and new. ![]() Last edited by Vogue on 10th Jun 2014 9:27pm. Edited 2 times in total |
Perce Member Since: 30 Jan 2012 Location: Milton Keynes Posts: 163 ![]() ![]() ![]() |
[b]Tyres will always be a subjective thing, but IMHO why have a very expensive (both to buy and run) high performance vehicle, and then want to skimp
Will, why are you giving tyre safety advice when you're running winters on the front and summers on the back? It's like Kerry Katona giving financial advice. |
Cos the tyre combo I have would only be unsafe on snow, not on normal road conditions |
So Winters on the front and summers on the back is OK in the fast lane of a motorway in the summer when there is a sudden downpour and emergency braking on a slippery surface required? (Just checking ![]() |
So far yes |
Using part worn tyres is as bad as using part worn brake pads. They have been removed for a reason and there's never any evidence to prove they didn't come from a crash damaged car. Whereas continuing to use a set of part worns on a S/H car is less of a risk although I tend to fit new ones as soon as I can.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3940 ![]() ![]() ![]() |
This tyre argument feels like the sort of snobbery we all hate - or do we?
No Geoff, I've said I don't like Nexens which hare a mid-range tyre. But I would take a new set of Nexens over a set of part worn Pirellis any day. Safety, not snobbery. I can drive to accommodate a lesser handling tyre but there's no compensating for the unknown or unpredictable.
The only thing I've bought secondhand is a grill and bumper for a front end conversion and am currently regretting it, but if and when it gets done its for me not the neighbours as I like the look - just in case others pipe up.
I see your reasoning. BUT new tyres can be just as much of a risk. IIRC there are members who have experienced issues with premium brand new tyres... Tyre treads coming away from canvas's or leaving in chunks if i recall.
My final point.....
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6378 ![]() ![]() ![]() |
It's a good point, and very well made.
