![]() | Home > Maintenance & Mods (L322) > How long should rear calipers last? |
RRBlue Member Since: 24 Feb 2012 Location: Cambs Posts: 226 ![]() ![]() ![]() |
Mine rears were originals and I replaced them at 170k, probably 10k tool late. The offside was sticking badly for some time although I did not realise it. I replaced them with all the bolts, clips and flexible hoses on both sides and all is now much better. 2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1201 ![]() ![]() |
On my previous Td6 - with TRW calipers - the ROS stuck at 6yrs / 80k ish.
Thanks for the replies.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3986 ![]() ![]() ![]() |
I think it's possible calipers seize because the brake pads seize first due to corrosion. The pistons then seize because of lack of any movement.
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
Both have been done on mine. Nearside rear in March this year at 71k and the offside at 59k in December 2012.
^^ My replacement refurbished calipers are identical TRW to the original - I'm certainly not qualified to recommend an alternative !
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8129 ![]() ![]() ![]() |
I needed new discs and pads, so replaced the rear calipers anyway.
Thanks, did you exchange for TRW calipers and where do you exchange them please?
