|  | Home > Technical (L322) > Delay when engaging 1st gear - new gearbox just fitted |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35880    | i'd get the oil level checked first ,
|  22nd May 2014 7:39am |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309      | Oil level it takes a while to get oil into all the nooks and crannies so new /recon boxes often needs a top up after a few hundred miles.   | ||
|  22nd May 2014 8:01am |
| Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1244      | Great to hear it is common on brand new boxes. I new it was a potential sign of failure on an old box. Was initially worried my new box might be damaged after 100 miles on it. I will contact the mechanic and get it booked in for a top up. Tom
|  22nd May 2014 8:15am |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | Also worth informing the gearbox specialists asap just incase you find its something worse! But does sound like low fluid... RRPhil would know/be able to better advise you...  | ||
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782      | Maybe the new box tried to p*ss on the parking wardens and lost a bit too much there   | ||
|  22nd May 2014 9:36am |
| Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1244      | Yep shame the car did not drench them....
|  22nd May 2014 9:49am |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782      | Hope it is a quick and easy fix, i.e. top up the ATF. MY 2010 5.0 SC Galway green and sand interior!!
|  22nd May 2014 9:51am |
| Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1244      | Dropped it off and auto box specialist thought it might be the oil valve from the torque converter that is meant to hold oil when the car is parked so that when started again has oil ready for immediate engagement. He is carrying out diagnostics tomorrow morning with the car cold and will get back to me. Tom
|  22nd May 2014 8:46pm |
| Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1244      | After 2 weeks diagnostics and being checked out by the torque converter company (that supply LR)  they have found the issue to be a non return valve on the TC, it was faulty and sometimes draining the oil when parked so that on start up it took time to build up the pressure.
|  13th Jun 2014 9:08am |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35880    | that makes sense, hope its ok now..  | ||
|  13th Jun 2014 9:14am |
| Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1244      | Well, just had a call from the gearbox company, the problem is still there in 2 out of 10 start up gear selections so now the torque converter company is going to do a complete rebuild. Then my gearbox company will check it for a day before returning it to me.
|  13th Jun 2014 11:49am |
|  13th Jun 2014 11:54am |
| Posting Rules
