![]() | Home > General > withdrawal symptoms |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 ![]() ![]() |
Glad you got it sorted. |
vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390 ![]() ![]() ![]() |
car is now with dealer for a month to resolve some additional issues including a misfire, especially when the car is cold. Other issues are:
The misfire is a strange one, is it always the same cylinder or does it move around. Have the injectors and knock sensors been tested? All the wiring and connectors? Has the engine management ECU been reflashed with the most recent software? Have all the ECUs been reflashed? Has the fuel system been cleaned? Has compression been checked?
Eugene
must be no 8 cylinder |
just got my car back from the dealer. i have an out of town meeting tomorrow - there and back 750kms (470miles) - so hopefully everything's been sorted fully
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Vnitos...what was the noise from the rear left wheel related to the ETM diff??
@Paul: the noise was very intermittent, basically once-off and happened very rarely. The dealer's service manager described the noise as "sounded like something fell off the car - I almost $hit myself".
Cheers...sounds nasty GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
did a trip of 750kms yesterday - can't describe the difference in ride comfort between the Fattie and the Freelander loaner I had.
Well that sounds promising !!! I hope it keeps on going well from now on |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16398 ![]() ![]() ![]() |
If you have the cats removed and it brings on the EML try spacing the lambda sensors out (away using washers or alike) that usually solves the issue |
