![]() | Home > Maintenance & Mods (L322) > 4.2 New rear brake caliper - What to do with this? |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048
Wire brush it and silver paint |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883
i've just sprayed my front callipers in satin black and intend to do the backs the same, maybe do both yours black ryan?.. ... - .- -.
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6839
Or caliper paint in your choice of colour? Got - 2017 SDV8 Autobiography in Loire Blue
| pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218
Thanks, so:
| TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1201
The bracket arm you are talking of is the carrier.
The calliper carrier (thats what its called |
Thanks chaps... Both replies very helpful, as ever |
i did spray over the brembo logo ryan...i'll get some stickers off ebay and re-apply the logo..
| Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947
I painted mine in situ with silver smooth hammerite and a brush turned out great and saved a lot of hassle removing etc |
| RRBlue Member Since: 23 Feb 2012 Location: Cambs Posts: 226
I painted and lacquered my new calipers after masking the piston. Had them done in advance of fitment. After paint I fitted new slider bolts etc.
A quick note to all you keen DIYers reading this thread... If you paint your callipers DO mask off the threaded holes, bleed nipples and pistons where possible (especially on Brembo's) as A, the bolts can tighten on paint then work loose during braking VERY VERY IMPORTANT!!! & B, paint can affect the piston seals etc etc etc |
| Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675
Good advice |
Indeed. Makes all the effort trying to mak the piston seals worthwile. Seriously tedious but worth it. 2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
Thanks again for the interesting replies.
| All times are GMT |
