Home > Technical (L322) > RR 4.4 TDV8 2011 Exhaust System, Normal: 2 or 4 tail pipes ?
bwelton
United Kingdom 2012 Range Rover Vogue SE TDV8 Zermatt Silver
Hi All,
I am looking to buy a 4.4 and have seen one, but observed that the exhaust is different to the other TDV8 4.4's that I have seen.
The exhaust is all located underneath the car. With the exception of this car all the others have 2 x exhaust coming out of the back box on either side i.e. total 4. On this car there is only 1 x exhaust on each side.
The car has done <20,000 miles and is on an November 11 plate. Was this standard or has this had another separate exhaust system replaced. If it has been replaced, then this would seem odd for a 2 1/2+ year car with less than 20,000 miles ?
Any ideas if it is standard for that year / model or what could have happened ?
Many thanks
Post #266054 18th Jun 2014 10:59am
mmiata
Hungary 2012 Range Rover Vogue TDV8 Buckingham Blue
mine is sept 2011 production with 10k miles and looks like this
should have 2x2 pipes 4.4 TDV8 Vogue Buckingham Blue MY12
from Hungary
Post #266072 18th Jun 2014 12:19pm
bwelton
Thanks for the photo mmiata, the one I'm looking at is a little later November 2011 rather than September
but I would not have thought it was changed.
Yours is superb condition underneath !!, the one i'm look at is not so good. It was originally owned by Land Rover and I suspect a Demo model as it has the all-round cameras. I guess there is a possibility that the Exhaust was changed.
Has anybody seen a TDV8 4.4 with just a single exhaust on each side of the back box ? Could there be any issues with power being limited by exhaust flow ?
Thx Bob
Post #266073 18th Jun 2014 12:33pm
mmiata
I`m quite sure LR did not change on exhaust design during those few months! Smile Moreover on mine the date of manufacturing is October (instead of Sept, as now I have checked) so registration might been in November as well.
The one you are looking on the pic also having surround cams but this have nothing to do with exhaust or demo vehicle...
I would be cautious with a vehicle which required exhaust change under 20k. Although at a good price...
Then you should have a good look around what else might had been changed or damaged. 4.4 TDV8 Vogue Buckingham Blue MY12
from Hungary
Post #266078 18th Jun 2014 1:17pm
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
Just checked mine which is sept 2011 and has the 4 pipes. Any chance of a picture of yours as I'm intrigued. Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #266083 18th Jun 2014 1:25pm
bwelton
HI mmiata, Pfazz,
I cant get a photo at the moment until the delivery post sale completes. Essentially it has one tail pipe on either side of the back box rather than 2 on each side.
Sounds like the exhaust has been changed with the earlier owner/s. The first owner was Land Rover, it's listed as Land Rover Internal Fleet in Bicester UK. I just wonder now if it was damaged as a test vehicle.
Thx Bob
Post #266098 18th Jun 2014 2:47pm
Sounds more like a 3.6 or TD6 set of pipes to me... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #266102 18th Jun 2014 3:11pm
bwelton
Hi All,
Is it possible for a few more people whom have MY11 and MY12 4.4 TDV8's to check if they have 2 or 4 downpipes from the Exhaust backbox. There are some different views, so I'd like to get real world sample checks of cars.
thx
Post #267475 26th Jun 2014 4:12pm
silversurfer
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Orkney Grey
Why don't you pay a dealers forecourt a visit and have a look at a selection of vehicles.
That's got to be worth the effort.
Post #267477 26th Jun 2014 4:22pm
dhallworth
Our 2012 4.4 TDV8 has 4 pipes - two on either side as pictured above. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #267488 26th Jun 2014 4:45pm
Vogue
Just a word of warning, LR ex management vehicles / ex LR Experience - check, check and double check for underside damage - exhaust, floor pan, chassis/sub frames spoiler and trim - many are damaged due to OffRoad use. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #267510 26th Jun 2014 6:59pm
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
my december 2011 TDV8 has 2 pipes on each side.
Post #267663 27th Jun 2014 4:56pm
bwelton
I have now found out the situation.
A 4.4 TDV8 of 2011 / 2012 should have 4 x tailpipes (2 either side of the backbox).
However some cars that have been within the Land Rover Fleet and used in the Land rover Experience had experienced problems with water going back up the tail pipe and damaging the DPF. As a result Land Rover had some vehicles modified to have a non standard exhaust fitted with 2 x tail pipes. These were intended to reduce any flow of water (whilst submerged) back in to the Exhaust / DPF.
In this case, the non standard exhaust was not returned to standard exhaust when it left the Land Rover Fleet.
This is the case with the car that I have been looking at, but may not be the cause for any other RR 4.4. TDV8's out there.
The good news is that LR were very helpful in sharing the pieces of the information for my research. I was also separately advised to have a a full inspection performed given it's LR Experience fleet history.
Post #267678 27th Jun 2014 6:14pm
