![]() | Home > Technical (L322) > Check Coolant Message |
I suggest to drain the coolant tank and fill it with new mix and see if that helps. Otherwise your sensor (plugged into the bottom of the tank) may be faulty a bit. I replaced mine (don't forget to remove the tiny rubber cap on the tip of the probe before installation) and the message went away (with the correct mix). The sensor wasn't very expensive I remember. MY 2010 5.0 SC Galway green and sand interior!!
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1200 ![]() ![]() |
^^ Had the same recently on my 2006 80k 4.4 AJV8 - with a check message twice over a couple of months.
I did a howto on just replacing the sensor (which is easy and doesn't require a drain down) but this doesn't always work, and sometimes the only way is to replace the coolant tank. CTC was going to cut an old tank open to see how the sensor works, as if you can replace it without draining down it is not in the coolant so there may be a sight glass or similar in the coolant tank. .
