Home > Wheels & Tyres > Tyre Pressures |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
Mine's an 2008, but I've got 36 front, 42 rear on 20s if I remember correctly. |
18th Jun 2014 7:16pm |
Bagus Member Since: 15 Apr 2014 Location: London Posts: 179 |
There should be a sticker on the drivers door trim but I'm running 36 front and 40 rear if its any help. |
18th Jun 2014 8:04pm |
iphs Member Since: 07 May 2014 Location: Norfolk Posts: 198 |
Tyre pressure depends on size, type and use as much as anything else. if you tow a lot you should to put a couple of pounds extra in the rears. If you go off road you might want to let a few pound out all round (depends very much on terrain).
18th Jun 2014 9:10pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Those figures relate only if the car is fully loaded. I made the same mistake. If you check the sticker for 4 adults plus baggage you should have 33 in front and 36 in rear. Now as I'm mostly in the car on my own I have set my fronts to 31 and rears to 34 makes a huge difference to the ride as wil recommended at 33 front and 36 rear. 42 in rear is far too hard. Present :2008 TDV8 HSE
18th Jun 2014 10:23pm |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 |
Thanks for the info. I have Pirreli Scorpions and all week it is just me with the wife and kids at the weekend and no towing, mix of urban streets and dual carriageway for 25 mile commute.
18th Jun 2014 11:06pm |
The sidewall pressure indicator is, as you say, a maximum pressure, sorry I didn't make that clear.
19th Jun 2014 7:29am |
