![]() | Home > Maintenance & Mods (L322) > Bleed Screw Fix? - PTFE Teflon Tape (Coolant Loss) |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
Sorry Ryan, but there's only one thing that'll save you now. It's the Ghostbusters song...
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35829 ![]() ![]() |
see, i told you you had a screw loose.. |
Yes Stan but you've not told the forum why! |
sweaty1 Member Since: 15 Mar 2016 Location: kent Posts: 5 ![]() ![]() ![]() |
I know the sis an old post but if your bleed screw has an `O ring then take it off and refit it reversed . They compress and taper over time . If not then new one or PTFE tape . O ring better fix though 2006 Thailand G4 Event Press Vehicle and still working hard |
Or use gasket sealant or similar, that worked for me |
