![]() | Home > Maintenance & Mods (L322) > Front air springs replacement. Short cut. |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
I did mine last year without a manual. I didn't realise you were supposed to disconnect the ball joints and brake calipers. I didn't. The only hard part was getting the large bolts out. |
netsonic Steve Member Since: 06 Oct 2010 Location: Sussex Posts: 165 ![]() ![]() ![]() |
how did you re pressurise the bag before lowering to the ground, ...........is it a simple case of replace fuse and switch ignition on.......... |
I just started the car and they inflated. |
birchyman71 Member Since: 19 Feb 2013 Location: stockton on tees Posts: 147 ![]() ![]() ![]() |
I did mine a few weeks back in exactly the same way but before inflating I lowered it on to low axle stands to take the weight before starting the car up to inflate them , I would advise getting the alignment checked as you can't be 100% sure it's the same and for the sake of £30 it might save wrecking some tyres |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1527 ![]() ![]() |
great shortcut. I would be tempted to (when the car is back settled and the bags reinflated) loosen and re-tighten the bolts holding the arms to the subframe to ensure the pre-load is not messed up.
