Home > Maintenance & Mods (L322) > OIL LEAK!!
Plumber cae
Wales 2002 Range Rover Vogue Td6 Zambezi Silver
OIL LEAK!!
Looking for some advise...... Bought my rr a few months ago, first l322 td6 130000 miles have had the 4.6v8 p38 hse previously. Just got home and noticed a small spot of oil where I usually park so had a look under and seen oil all around the front near side drive shaft at the diff. Just wondering if this is diff oil or engine oil? There is nothing dripping down on that area from anything else. If it was a simple job then I will do it myself. Since I bought it it has sprung a diesel leak, center screen had stopped working and the water pump blew up!!!
Post #266314 19th Jun 2014 8:55pm
JAYBOY
Don't bring it my house with oil leaking all over my oil free drive. Thumbs Up
Get into off road height and get underneath the beast. with you being so short you may be able to walk under the car in off road height Laughing , Have a look to see if coming from the engine.
Also put some of the oil on your sausage fingers and smell it there is a distinct difference between engine and hydraulic oil.
I hope this helps. 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #266318 19th Jun 2014 9:02pm
Check the oil filter reservoir as they often spring a leak (if the seals are not changed during servicing) and it drips down that side of the diff Thumbs Up
Post #266319 19th Jun 2014 9:03pm
Plumber cae
Will lift it up after work tomorrow, will check that reservoir tomorrow thanks for the tip!! Was thinking about changing the oil on the weekend anyway and I now know the perfect place to do it Jayboy!!
Post #266325 19th Jun 2014 9:11pm
JAYBOY
Laughing Laughing Rolling with laughter Rolling with laughter 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 Skoda VRS
Post #266326 19th Jun 2014 9:13pm
Plumber cae
Forgot to mention that I changed out the old style crankcase breather last week for the updated style, wether this has anything to do with it, I doubt it as it's on the opposite side to the leak.
Post #266329 19th Jun 2014 9:18pm
Plumber cae
Got a pic of your rr then Jayboy?
Post #266330 19th Jun 2014 9:20pm
JAYBOY
Have a look in my gallery Shocked 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 Skoda VRS
Post #266340 19th Jun 2014 10:03pm
netsonic Steve
United Kingdom 2002 Range Rover Vogue Td6 Epsom Green
i have a 2002 TD6 and i have a minor leak as you describe which i think is the seal between the sump and diff, £8 for the seal bitch to change so as i dont get any drips just a bit of oil stain around the diff ive not tackled it just wash it off every few months................it leaks less when ive done an engine oil change
Post #266344 19th Jun 2014 10:14pm
And don't go under your car in off road height without putting an axle stand or two in place, just in case!
You could also try cleaning off around the front diff plug, and checking for tightness - 14mm drain plug key.
But sounds more like the sump/diff seal..... .
Post #266348 19th Jun 2014 10:24pm
Plumber cae
Thanks all, will clean it up tomorrow and have a proper look with the axle stands !!! Will keep you posted!
Post #266349 19th Jun 2014 10:29pm
Plumber cae
Not an easy fix...... Defiantly the oil sum seal!! Anyone done this before?? Or any advice? Thanks
Post #266484 20th Jun 2014 7:50pm
