![]() | Home > Duckworth Parts > Oil seal |
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
Ouch, could be an expensive diff rebuild! I would drop the oil first and inspect it for water ingress (rusty sludge) We have found quite a few that have corroded the driveshaft/internal components (hence the seal failure) |
| duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217
Seal TBX000110 would be £15.90inc vat You can paypal direct using - www.paypal.me/duckworthparts
| DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 798
Changed the oil in it about 6 weeks ago. Was surprised how clean it was. At the moment, just looks like a seal failure. |
| ohuntsman Member Since: 21 Mar 2016 Location: Cornwall Posts: 341
I've got the same leak - how easy was the job?DO you need the press tool? Does the flange release easily with a tap? how hard is the lower arm to hub bolt to undo & redo? |
