Home > Maintenance & Mods (L322) > Tow Bar
Muttley
United Kingdom 2008 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Tow Bar
Lo Peeps
I want a tow bar fitted
Now I really haven't got a clue with things like this but basically need some advice on where is the best place in the region of Heathrow to get one fitted and what sort to go for bearing in mind I will only be pulling a small trailer for a mobility buggy.
Oh preferably one that can swing out of the way if one exists Thumbs Up
Any advice would be welcome.
Thanks in advance
Cheers
Dave Current : 4.2 S/C, now Sold Sad
Previous : V70 Volvo, S40 Volvo ( a very reliable old banger ), E39 M5, Carlton Diplomat and the list goes on Smile
Life Sucks but ya just have to do the best you can with what you have !
Post #267290 25th Jun 2014 12:53pm
sako243
It's really not that difficult to fit one yourself if you go for the genuine items (got mine from PF Jones), I did. The only difficulty I had was that the bolts that held on the exhaust were seized. Managed to shear one and get the other off by removing the rubber bung, once they were out of the way I cut / drilled them out and replaced with bolts.
Took about 1/2 a day to do it in total (I split it over an evening and morning because of various circumstances).
I'm not sure of a swing-away one for an L322 but all the genuine ones are detachable, if you go for the swan-neck (I didn't) then that fits into the hole under the floor on the right-hand side of the boot so out of the way.
The main question is do you already have the armature (big metal bar going across underneath the back of the vehicle)? If yes then you'd only need the tow hitch bit.
Post #267302 25th Jun 2014 3:38pm
^what he said, pf jones is your friend if you want to do it yourself, or any tow bar centre should be able to handle it.
Specify if you want:
Detachable or farmers (farmers can be removed but detach is neater) you want a westfalia oem setup not brink/thule/witter, which though ok in isolation just dont look right on a ff, have had brink and witter bars on other cars and they are good pieces of kit so im not knocking them, just an aesthetic thing.
Only specify GENUINE electrics, for ease and peace of mind, last thing you want is the cutting wiring. You could buy these yourself from LR and get the fitter to install them. Some say it needs coding, but the jury is out, they seem to work ok without, however i suspect that enabling in ccf will switch on stability systems and such.....
But really it a piece of p155 to fit in comparison to others. There is nothing that can't be fixed with a hammer😜😜
Post #267388 25th Jun 2014 10:58pm
sako243
Got genuine electrics on mine and only thing I did when installing was to disconnect the battery in the proper manner.
Post #267389 25th Jun 2014 11:01pm
Yes they do work, but there is an option to enable tow bar in the config files, so the question is what does that actually do?
Engine and gearbox mapping? Traction and stability control? Who knows...... So long as the lights work! There is nothing that can't be fixed with a hammer😜😜
Post #267390 25th Jun 2014 11:04pm
sako243
Or in my case not. First time went to tow a trailer (another Land Rover) got both trail lights and one indicator on?! Turns out I'd put the white socket in the black holder and vice versa so inadvertently plugged it into the caravan socket. Thankfully a quick fix. Maybe next time I pop into the garage I'll ask if they know what enabling the option does.
Post #267392 25th Jun 2014 11:08pm
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
I think it is only the later (post 2010) vehicles which need coding. Mines a 2006, and when I recently fitted a towbar and 13 pin kit for towing our tin tent, without having to have anything coded the car knows when the tin tent is on the back, and the engine and gearbox mapping is altered (clever ba Censored rds, these chinese!!)
Thumbs Up Thumbs Up 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #267397 25th Jun 2014 11:54pm
160dmb
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
So can anyone tell me what changes are made on a post 2010 car then please?
Also do I need a dealer to do the changes? 2016 (L405) Autobiography in Black with Ivory - for ULEZ
2014 (L405) VSE in Black with Ivory
2011 (L322) VSE in Black with Ivory
2005 (3.2 V6) Porsche Cayenne in Black with Savanna
1999 (P38) VSE in Burgundy (?) with Sand
Post #267422 26th Jun 2014 9:20am
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Not sure how this would be implemented - big difference between a bike rack and a tri-axle Ifor Williams with three tonnes of cow in it. Certainly never noticed any difference other than what you'd expect with the load.
Post #267428 26th Jun 2014 10:28am
jarv
My Westfalia detachable and 13 pin electrics were supplied and fitted a couple of months back by P F Jones, and I live in London. They obviously have a relationship with a mobile fitter down here. Top job and good value.
Post #267448 26th Jun 2014 1:39pm
mzplcg
Different wiring loom, the towing socket wires are a lot shorter and there's no white box controller to fit. The coding seems to ensure that when towing the rear park sensors and rear fog lights on the car are disabled.
Post #267453 26th Jun 2014 1:56pm
Muttley
Many thanks for the help Guys Thumbs Up
Cheers
Post #267536 26th Jun 2014 9:23pm
SO3isme
Hi, I am missing the swan neck on mine at the moment. can you say exactly what 'fits into the hole under the floor on the right-hand side of the boot so out of the way.' means please? Is that in with the spare wheel?
Thx.
Post #267537 26th Jun 2014 9:29pm
Philip
Post #267538 26th Jun 2014 9:35pm
SO3isme
Thanks! I didn't know about that, and my car is away having the A/C condenser replaced.
Post #267566 27th Jun 2014 5:32am
