![]() | Home > General > Potential New Owner - S/C or TDV8? |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2074 ![]() ![]() ![]() |
Was the TDV8 you drove the new 4.4? |
johnson1 Member Since: 30 Aug 2010 Location: South West Posts: 519 ![]() ![]() ![]() |
Nope it was a 3.6 which whilst very smooth was quite slow compared to my current car. |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 ![]() ![]() |
If the fuel economy isn't an issue I'd go for the S/C. But it's only something like 2 seconds quicker to 60mph than the new 4.4 TDV8. So you're going to be looking at a slower vehicle than you've got anyway. The FFRR is certainly not a racing car, even though modern ones are quite rapid. (in a straight line)
Mounty Member Since: 29 Jan 2009 Location: Allschwil Posts: 311 ![]() ![]() |
Oh if mpg and resale value is no concern I have the 5.0l |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
If fuel cost, annual milage and big depreciation are not an issue then a late plate used 5.0litre S/C is the way to go and let somebody else take the bit depreciation hit, otherwise the TDv8 is a lovely creamy smooth engine that does a pretty good job of thrusting a nearly 3tonne brick through the air. You can use the Land Rover UK website to search for late plate cars at dealers. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
RRV Member Since: 05 Oct 2009 Location: Midlands Posts: 648 ![]() ![]() ![]() |
SC |
+1 |
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 ![]() ![]() ![]() |
John - I recently changed from a big fast merc (CL in my case) to a FFRR - TDV8. Admittedly I didn't try out a SC but with the mileage I do (about 25k per year) that would have been a nonsense anyway!
DISAGREE - The TDV8 suspension may not be up to it, but the SC suspension and brakes ARE. I noticed the TDV8 (3.6) was very wallowy in comparison to my 4.2SC when last I was in one.... The 5.0SC is amazing......try BOTH if fuel is not an issue - I do about 30,000 miles a year and I love petrol ![]() XXXXXXXXXXXXXXXXXXXXXXX Previous XXXXXXXXXXXXXXXX 2009 5.0V8SC Autobiography 2006 4.2V8SC Autobiography 2004 4.4V8 Vogue |
Thrasher, does the 2010MY have the trick hydraulic anti-roll bars that the RRSport S/C has? I had the system in my TDV8 Sport and it was just amazing how fast that car could go round corners and remain totally roll free and flat. The FFRR Tdv8 doesn't have it and I have had to slow right down for corners that I could take at much higher speeds in the RRS. The other thing that the FFRR TDv8 doesn't have that the RRS version did have was the Brembos............................ FFRR braking is nowhere near as progressive or as confidence inspiring as the RRS on huge Brembos, the FFRR also takes a lot longer to shed speed than the RRS ever did, yet FFRR is a lighter car!
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 412 ![]() ![]() ![]() |
At the time, the tdv8 and the 4.2 SC shared the same suspesion, brakes, and general setup... Maybe you tired a bad example |
TDV8 (at least the MY07 Vogue SE that I am basing my comparison on) got the suspension from the then current SC model and does have Brembo's (although not sure if they're the same size as the SC).
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2622 ![]() ![]() |
Unfortunately not. Would be a popular option as a proper RR without the body-roll would be pretty much ideal. Perhaps something for the likes of JE to offer? |
