Home > Maintenance & Mods (L322) > Hate electrics |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
The chances are your two faults are unrelated unless you have a bad earth connection.
1st Jul 2014 9:02am |
mudknight Member Since: 21 Sep 2012 Location: birmingham Posts: 73 |
Thanks very much , sorted those two out ,, next all cigaret sockets stopped working , checked fuse in boot and that's ok , any ideas ?? |
1st Jul 2014 1:14pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6666 |
I had a similar problem when I "accidentally" shorted out the connections in the rear 12v supply. Checked every fuse, all were fine, but still no power.
1st Jul 2014 1:21pm |
How many fuses are there for the cigaret lighters ? As I can only find the one in the boot |
1st Jul 2014 3:50pm |
There is a cig lighter fuse in the front as well, can't remember which one exactly but better check MY 2010 5.0 SC Galway green and sand interior!!
1st Jul 2014 4:07pm |
Fuses 1 and 7 on the rear fuse board both 20A depending how your car is wired.... there's two options.
1st Jul 2014 4:10pm |
May be I should have also said she is a 2003 TD6 ,, |
2nd Jul 2014 8:24am |
The above applies to your car.
2nd Jul 2014 11:28am |
