Home > Technical (L322) > FFRR rear light assembly
kin
England 2006 Range Rover Vogue TDV8 Zermatt Silver
As one of my rear light has scratches on it, I'm currently bidding on another light from ebay.
Could anyone advice on whether they will be exactly identical in terms of electrics which will plug straight onto it?
Post #2689 31st Jan 2009 1:21pm
Full fat not diet
England 2004 Range Rover Vogue Td6 Zermatt Silver
In a simple answer Yes as long as it is for that shape and the right side of course Good Luck Thumbs Up
Post #2690 31st Jan 2009 2:54pm
kin
Thanks Thumbs Up
Post #2691 31st Jan 2009 6:10pm
Kin before you do check this out
How to remove rear lights?
Simply lift down the rear tailgate, remove the two screws from the side of the light, that will be easily seen when the tailgate is lowered.
Now look at the light from the side of the vehicle and you will notice two small notches about one inch down from the top of the light and one about the same distance up from the bottom, you need to lever the light from these notches.
So take a large flat bladed screwdriver, wrapped in a tea towel or cloth, to protect the paint work and insert it in the top notch first and gently lever the light forward, start off by just moving it slowly and then move the screwdriver down the the bottom notch and just repeat the process untill the light starts to move.
Just be brave and watch the paintwork!!!
some brute force got this done in the end, the 2 retaining lugs hold strong, you really do have to be brave.
Just removed my R/H rear light the other day (FFRR SC). And yes they do sit very tight in those holders. The upper plastic "insert" is a part of the lamp assembly body but the lower is a loose plastic "clip" which in my case broke when I gently took it off??? It looks like it is designed to break before the lamp itself and I was confident that I could just go to Land Rover and buy another one....
BIG SURPRICE????????
This little plastic clip is a part of the lamp and cannot be purchased alone? How stupid is this?
I am sure I am not the only one because I ended up with having to unscrew the holder and use 2 set of pliers to take the broken bit out of the holder that is how tight it was. Surely I am not the only one?
Anyway, Land Rover suggested that I glued the old one onto the lamp and that is exactly what I have done.
Not very nice on an almost new 100K car but it is the only option.
Good luck and be extra careful on those lower clips..
Post #2693 31st Jan 2009 6:50pm
Full fat not diet
I use a credit card - less likely to damage paintwork and works just as well Thumbs Up
Post #2694 31st Jan 2009 6:57pm
kin
Thats a really good idea Thumbs Up But I might take it to the indy rover specialist to change it for me Embarassed Don't fancy breaking it !!!
Post #2695 31st Jan 2009 7:11pm
Full fat not diet
i have changed a few sets and never broken one to date - takes no more than 10 minutes to do a pair Whistle
Post #2696 31st Jan 2009 7:37pm
I asked the same once upon a time, here was the answer:
http://www.fullfatrr.com/forum/topic60.html?highlight=rear+lights Discovery 4 HSE
1993 90 Tdi
Post #6412 12th Jul 2009 12:10pm
