![]() | Home > Technical (L322) > Standard hight settings |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35881
493mm front and 483mm plus /minus 3/5mm
joe90 [tim] chart
| Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902
Thank you Stan
After the garage had done a reset on the air sus inactive on Monday, they recalibrated all the corners to 740mm, just wondering if and why are the settings in the above picture are 20mm lower at the rear ( except access hight 10mm)
all the front height settings are only 10 mm higher except for the 20mm off road which i presume for more clearance to benefit the front ...
well I spoke to soon, message back, roll on Monday when post arrives, then I'll sort it myself and find out why all of a sudden Im getting 'air sus inactive' with no bong and light locked on standard height |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002
The front could be different as the wheel arches on the body may not be the same height, in fact, I'll say they are not. When the car sits level, the rear arch is nearer the floor - you are not measuring from the same datum. If you took the reading by measuring from the bottom of the front rim to the top of the bonnet, it would be an even greater reading than the rear measurement, but the car would still sit correctly in the same place, if you see what I mean ?
Tool arrived, faults cleared found 2 others, posted else where though, and found steering ball joint foobard !
Now I thought I saw it posted on here, I looked in the LCM light section but wasn't there....hmmm go and looky again |
sorted, found it |
| All times are GMT |
