![]() | Home > Technical (L322) > TDV8 rear brake discs |
Im planning to do this too. I understand there is an inspection hole. This is to wind back epb mechanism so you can remove disc. Im not sure exact process here but be careful to wind correct way. Present :2008 TDV8 HSE
g1968g Member Since: 24 Aug 2013 Location: Fife Posts: 89 ![]() |
Sorted, put the wee hole ot 6 o'clock and adjust the shoes "in"
I'm planning to do rears discs soon. Just not clear on inspection hole bit / EPB . What do I need to do exactly ? |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 912 ![]() ![]() ![]() |
Once you have the wheel, caliper and caliper carrier off, remove the small black plug from the rear disc between two wheel studs.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6823 ![]() ![]() ![]() |
See section 8 - http://www.disco3.co.uk/gallery/albums/use...ssPics.pdf Got - 2017 SDV8 Autobiography in Loire Blue
Thanks chaps |
Hi,
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8765 ![]() ![]() ![]() |
When you have fitted new discs run the pad bedding in cycle, instruction on rave, an handbrake will work much much better. |
