Home > Maintenance & Mods (L322) > Tracking Issues |
trickymickey Member Since: 28 Mar 2014 Location: Worksop Posts: 46 |
Reset tracking today so all track rods were equal lengths. Then remounted steering wheel .Now have to recalibrate steering angle sensor to lose the lights on dash !. |
3rd Jul 2014 5:00pm |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1490 |
Good info, thanks.
3rd Jul 2014 5:09pm |
No I too thought that , but not the case, only started this saga to eradicate a clunking/knocking noise from the O/S/F but to no avail, still present . Seems like a lot of people have had the same thing with no definitive answer ! |
3rd Jul 2014 6:25pm |
iphs Member Since: 07 May 2014 Location: Norfolk Posts: 198 |
Is it not just a case of going through the battery disconnection - reconnection routine and then doing a lock to lock reset.
3rd Jul 2014 7:09pm |
Sadly no ! tooka fair bit to centralise the steering wheel .so only a recalibration will suffice . |
3rd Jul 2014 10:27pm |
Had a run out to a independent today not far from home, got steering angle light and other lights turned off with genuine autologic, as Snap on Solus wouldnt do it or Launch, £20.00........not too bad !. car seems well planted to road and feels taut !. Noise from front end seems to have disappeared too, result !.
4th Jul 2014 10:57pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
I would warn you against fitting Polly bushes , it's OK to stiffen up a Defender the ride is already terrible but on a Range Rover you will totally trash the ride ' kind of defeating the purpose really and the lack of compliance will over stress other suspension parts . 2008 MY Supercharged
5th Jul 2014 2:19am |
I would also advise not to fit polly bushes, OEM from Land Rover will give a much better result.
5th Jul 2014 8:34am |
Can you buy standard ARBs for the L322? I thought they were bonded onto the ARB so you had to buy the whole thing? |
5th Jul 2014 9:09am |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Yes they can be nasty too tight and can damage suspension parts. Present :2008 TDV8 HSE Gone Audi A5 2.7TDI Gone Discovery 3 HSE Gone Mercedes CLK Gone Range Rover 2.5 DSE |
5th Jul 2014 9:56am |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2926 |
Regarding the clunking- mine used to do that. I replaced the track rod end when it failed the mot and I couldn't get them off so I ended up replacing the track rods as well (following a tip from this forum- far easier to do it this way). I always replace stuff in pairs and so bought 2x track rod ends and 2x track rods, all genuine. Did the offending side to get me through the MOT and I still had the clunking. I then replaced the other side a couple of weeks later and the clunking stopped, so I can only assume that the noise was coming from the latter.
6th Jul 2014 9:38am |
