Home > Maintenance & Mods (L322) > Removal of face level vents
I have a need to remove both face vents, at each end of the dash.
The video below shows how it's done.
Unfortunately it doesn't seem to work quite so easily for me. I can pull back each of the spring clips holding the vent in position but when I release each one to go to the next one for release, the spring clip reverts back to it's "hold" position.
This is unlike in the video when it appears all you have to do is release each clip in turn and then pull out the vent.
As far as I can see I would have to hold all 4 clips in the release position simultaneously to release the vent.
Has anyone done this recently using the method shown in the video and if so can you help by explaining what I am obviously doing wrong. Big Cry
Post #269640 8th Jul 2014 11:30am
marshy
Australia 2015 Range Rover Vogue TDV6 Aintree Green
Mate I had to use 2 screwdrivers and do one side at a time. Once u get those springs on one side in pull it a little and then do the otherside thats how I had to mine I even had to get the other half to have a go as I ran out of patients a few times
Post #269645 8th Jul 2014 11:48am
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Just bend the tabs back, carfull not to go too far over as they'll snap but need to bend them far enough not for them to spring back home.
Thats what I did when taking the dash to bits to repair the pixels. If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #269649 8th Jul 2014 12:05pm
Thanks for the replies, both suggestions seem to be feasible, I'm just a bit wary of bending things that shouldn't need to be bent.
It does seem the video is a bit lacking in this matter which is surprising as I have seen the seem method shown in a Powerful uk video. Artistic license I presume.
Post #269670 8th Jul 2014 2:03pm
The Powerful FF does appear to come apart rather easily.
I suspect it's a well-rehearsed routine for them on parts that haven't been removed for the first time. Si. <This is my name.
Post #269681 8th Jul 2014 3:17pm
Sussed it Thumbs Up
The easy way to get the face vents out with out bending anything and which can be repeated again without damage is as follows.
Obtain an old credit card and cut from it 4 length ways strips each 7mm wide and with square ends.
Prise one of the 4 spring clips back with a bradawl or similar until the edge is evident and slide one of the strips behind it thus preventing it from retracting. Leave the strip in place. Repeat for the other 3 spring clips.
Then simply get hold of the vent and it will slide out easily.
To re-insert the vent, remove the strips of credit card and push the vent back into place, the springs will lock as you push the vent in.
Be aware, the spring clips are plastic, formed as part of the plastic vent shell.
Simples and not a video camera in sight. Very Happy
Post #269689 8th Jul 2014 3:50pm
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
Nice Job , good tip!! Thumbs Up Bow down 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #269690 8th Jul 2014 3:51pm
Another easy way is to use a radio removal tool, if you have one, the standard size "U" shape tool that fits Fords and lots of others are the exact size to release top and bottom tags on each side, simply push them in and pull out the vent, works on the center vent as well... Pete
Post #269705 8th Jul 2014 5:25pm
Welshdragon
Nice tip there, well done Thumbs Up . Now what you up to too take them out? If it dont work.......burn it!
Post #269769 8th Jul 2014 9:55pm
^ I need to get at a connector on the instrument panel to check continuity on a cable from there to the diagnostic socket.
A lot of work to check something but needs must. Rolling Eyes
Post #269771 8th Jul 2014 10:05pm
To be fair, PowerfulUK don't gain anything from doing these video's... Only helping their customers & those of you DIYers who view them for free on youtube... Bit unfair IMO to criticise the guys there for providing a free service to all! Just my 2p's worth... Whistle
Post #269792 8th Jul 2014 11:18pm
Wasn't really intended as a criticism it just seems daft to indicate a method of doing something on a "How to" video which patently doesn't work. Might as well show a method that does work. Powerful uk's vidoes are generally very good, a lot of them are however related to products they sell as "enhancements" and as such are commercially related to sales.
Post #269842 9th Jul 2014 8:31am
SteveMFr
Site Sponsor
Actually I've seen that vid and noticed this immediately too. I think Powerful UK does just bend the tabs back until the plastic creases and folds. Might even work a couple of times before they break off completely, but it is not the way it was intended. The spring action is there so that the vent is clicked back into the very tightes position automatically - and nothing rattles. The fold over methods are the kinds of things you see every now and again (done mainly by the likes of audio installers) and where the entire interior rattles at every bump.
I don't think that pointing this out is unfair - I'd consider it constructive criticism. The Powerful UK vids are great - and the owner (Simon?) is a really nice guy. But not everything they do is perfect. Especially that gas cap cover. Shocked
Laughing
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #269935 9th Jul 2014 3:00pm
