![]() | Home > Technical (L322) > Td6 Won't Start |
Fuel pump at rear wheel on its way out |
theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 305 ![]() ![]() |
How can we be sure? The garage checked the fuel pressures and he said they were perfect. |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2691 ![]() ![]() ![]() |
Sounds like an injector could be at fault, had the exact same, cranking on key for about 30 secs then away. |
Joncey Member Since: 24 May 2014 Location: St Helier Posts: 53 ![]() ![]() ![]() |
I will say fuel pump .
trainmanone Member Since: 26 Jul 2012 Location: stockport Posts: 201 ![]() ![]() ![]() |
had same problem myself soon after getting car ,turned out to be key had lost programing or something like that ,my lad had been messing about with hawkeye and goofed it up ,trip to independents and all sorted have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
Hey Guys.
Sounds like you need a better garage. |
The individual is very capable, however himself and myself have been extremely busy over the passed number of weeks so It's hard to get time. However - both of us are struggling because the injectors are good; showing no faults. the one which was slightly bad was replaced, the fuel pressure is good and the starter is turning perfectly. |
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 ![]() ![]() |
Can you describe the way you tested injectors? |
He did it using a kit. Placed the return or something into jars. Number five was releasing fuel, not a lot - however we replaced it because I had a spare engine. Is this the correct method? |
leak off only tests overflow
No, Once the car starts it run perfectly. We have not removed and tested the injectors. It's looking like we may have too.
It only starts currently with easy start. |
Hi pressure one is the mechanical one driven by timing chain
