![]() | Home > General > thoughts on remap |
| Pauld Member Since: 15 Mar 2010 Location: Sheffield Posts: 199
If it is a Td6 the remap does make a huge difference.
| m10rng Member Since: 19 Aug 2010 Location: london Posts: 64
"If it is a Td6 the remap does make a huge difference"-- is this because you have done this??
Yes, I had mine chipped as soon as I got it, and have done 90000 since.
he said to me
thanx |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
does the mpg go up, and if so , by how much.. ... - .- -.
| axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964
The MPG gets a little better but you have to teach your gearbox to shift up early to use the extra torque and to do that you must accelerate every where on as light a throttle as possible. It also seems to do another trick where to overtake hard you floor the throttle but lift off straight away and then plant the throttle and the car will now accelerate as hard as it can in a higher gear and I find this helps.
cheers axle, what about the statement that a remap might cause excessive wear on the gearbax etc.. ... - .- -.
| Nappler Member Since: 09 Jun 2010 Location: Surrey Posts: 158
Is a remap on a TD6 a pretty sure way to wreck the gearbox?. |
| Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313
Paul, is this the same car that eats gearboxes and diffs, which you mentioned in anoter post? |
As I said chipping can cause excessive wear.
got the car bak, got a tip from garage man to drive it hard for a full tank worth so engine can recognise the driving style and adjust.
| daveo Member Since: 21 Oct 2009 Location: london Posts: 2307
what about the petrol remaps, |
