![]() | Home > Technical (L322) > Td6 Won't Start |
| adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204
quite interesting story
My £1 bet goes on the fuel pump for what its worth... Exactly the usual symptoms... |
| theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 305
If its the pump - how does one know? The fuel pressure is good and the pump is making noise. |
You only need to be a couple of lb under pressure and it won't start! Will run all day long once started (ie on easy start) |
Right Guys.
| KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848
Mine wouldn't start last year for exactly the same reason - dodgy injector. |
| All times are GMT |
