Home > Technical (L322) > Manual shift problems
Java Jungle
Monaco 2011 Range Rover Autobiography 4.4 V8 Nara Bronze
Rangie went in for servicing today, all fine and updates have been done as well. Also, had a little problem with manual gear shift (just couldn't change gears manually, didn't come out of "D") sometimes. Apparently fault was fixed with the update, but driving home tonight same problem occurred....
Anyone experienced same issue and might know what's wrong?
FFRR 4.4/2011
Thanks,
JJ
Post #269706 8th Jul 2014 5:37pm
Java Jungle
Anyone???
Thanks,
JJ
Post #270177 10th Jul 2014 9:44pm
Do you mean the leaver wont move out of "D" or when you do it wont change up and down manually ?
Some one is bound to say it so I will , have you lubricated the link mechanism ? 2008 MY Supercharged
Post #270217 11th Jul 2014 1:42am
Axle, as it's a 2011 it will have the rotary knob & paddles instead of a stick...
Sorry can't help any further... Embarassed
Post #270221 11th Jul 2014 2:03am
ebajema
I suggest that you take it back and let them do a check on wiring and connectors. Although it is most likely software related by my guess TBH !! MY 2010 5.0 SC Galway green and sand interior!!
Post #270223 11th Jul 2014 3:04am
Sounds like software doesn't it ? time for your friendly local stealers Crying or Very sad 2008 MY Supercharged
Post #270227 11th Jul 2014 4:21am
ebajema
Take your own Vaseline, they charge you a lot more it Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #270230 11th Jul 2014 4:37am
Java Jungle
Thank you guys!
It doesn't do it all the time, yesterday morning was fine then in the afternoon didn't work and last night worked again...
Maybe a Mexican version, needs a siesta in the afternoon Rolling with laughter
JJ
Post #270283 11th Jul 2014 11:50am
Java Jungle
Just in case someone is going to have same problem in the future:
Wire was jammed when putting the top of the wheel on (Airbag)! Apparently I'm not the only one that had this issue.
JJ
Post #272344 23rd Jul 2014 10:34am
