![]() | Home > Maintenance & Mods (L322) > L322 4.4 Transmission temperature problem? |
Bagus Member Since: 15 Apr 2014 Location: London Posts: 202 ![]() ![]() ![]() |
I had the sensor fail on me. Drove 5 miles and got the "transmission overheat" message on dash. But later that day I drove
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1262 ![]() ![]() ![]() |
Had a similar problems a couple of years ago on a drive back to Wiltshire from Cornwall, got 6 miles from home and got the trans overheat gearbox mode. We ended up replacing the radiator and trans oil cooler.
Mistercorn Member Since: 01 Feb 2014 Location: Nottingham Posts: 109 ![]() ![]() ![]() |
That was my first suspicion as well, particularly as sensors tend to either work or fail. When it reported 34 degrees when I started the car up this morning having sat on the road all night that looks like a sensor issue.
I think the issue with the sensors is they rise but dont reset hence why it records a much higher reading than the actual temperature. Trick the system into thinking its actually overheating. Your IR reading would suggest sensor issues. |
