Home > Technical (L322) > Hesitation when pulling away gently, ok when more aggressive
Boat.Buoy
2002 Range Rover Vogue 4.4 V8 Epsom Green
Hi all,
2002 - 4.4 V8
Has anyone experienced the engine hesitating when pulling away? This happens when pulling away from rest when using light throttle movement. If I'm more aggressive then all is fine. This can also occur when accelerating from a low cruising speed, if the engine RPM is low (1500+/-) before you begin to accelerate.
The common denominator seems to be the accelerating from low engine speed.
My vehicle is converted to LPG, this issue is noted when running on either petrol or LPG. The engine has covered roughly 12'000 miles from new (replacement engine from LR, not rebuild)
Strangely, I have a friend with a 1974 VW Camper van, which over the weekend has developed the same fault. If both issues are similar in anyway, then perhaps the warm weather has something to do with it?
Any ideas of suggestions welcome.
Many thanks,
Matt
Post #270713 14th Jul 2014 9:44am
cowman
United Kingdom 2005 Range Rover Vogue SE Td6 Adriatic Blue
could be egr valve sticking
Post #270718 14th Jul 2014 9:54am
dont think petrols have egr valves...
split pipes or vanos seems to ring a bell Matt.... ... - .- -.
Post #270719 14th Jul 2014 9:58am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
PCV valve/hoses?
Post #270720 14th Jul 2014 10:04am
Boat.Buoy
Thanks for the suggestions, I was thinking PCV valve related after reading some posts online.
I'll have a look in to it.
Would anyone have a simple/recommended way of carrying out a smoke test?
Many thanks.
Matt
Post #270775 14th Jul 2014 4:19pm
