![]() | Home > Maintenance & Mods (L322) > power steering fluid |
netsonic Steve Member Since: 06 Oct 2010 Location: Sussex Posts: 165 ![]() ![]() ![]() |
As long as your not planning a trip to the north pole ATF Dexron IID or III will be fine...........£5 a litre here in the UK |
marshy Member Since: 20 May 2014 Location: Adelaide Posts: 34 ![]() ![]() ![]() |
Thanks |
frikkadel Member Since: 09 Mar 2016 Location: joburg Posts: 56 ![]() ![]() |
I am in south africa, so can i use the normal dexron ATF or is there a higher grade fluid? |
Andy K Member Since: 06 Jun 2016 Location: GL Posts: 48 ![]() ![]() ![]() |
See what your owners manual says in the back, as you are in a hot climate |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1583 ![]() ![]() |
I needed some for my L322 steering. Hunting around, Penrite have a 14315 equivalent PAS FLUID - (Power Assisted Steering Fluid) but it's $28/litre at SuperCheap. SuperCrap have 20% off all floor stock this Saturday 23rd. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
Alfasprint88 Member Since: 19 Dec 2015 Location: Kapiti Coast Posts: 25 ![]() ![]() ![]() |
Supercheap has 25% off over the ditch. Shall I get you some and post it to you? |
