![]() | Home > Maintenance & Mods (L322) > 2004 RR Random Alarm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
i guess a dodgy bonnet switch... ... - .- -.
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 ![]() ![]() ![]() |
As Stan says |
RangeK1D Member Since: 21 May 2013 Location: Calgary, Alberta Posts: 166 ![]() ![]() ![]() |
Hey Stan, would the switch need to be replaced or is it an adjustment I have to make. Also where exactly is it located on the hood (bonnet*)?
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Mine does the random alarm thing now and again too... Normally its the bonnet switch (make sure its not been leant on) and only just touches the bonnet |
Check the bonnet switch first as per the above replies. It was the problem on my 4.2 SC as well. MY 2010 5.0 SC Galway green and sand interior!!
Will be looking at it today, as soon as I find it |
Driver side (for you) above the wheel arch, close to the firewall. Sticks up like a sore thumb |
Just disconnect it for a few days, if all is well try the adjustments , if the adjustments fail it's new switch time |
Ebajema, Thanks! Located it and I have disconnected it, let's see what it does for the next week or so.
