Home > Wheels & Tyres > The Sidewall Appreciation Thread
Page 3 of 5 <12345>
RiccartonRR
Ah but!!!!!!!
The main use of my car is towing (tri-axle ifor) with a minimum of 3.5te behind it Embarassed The one problem with deep sidewalls is the flex with decent weight behind in corners makes the stability shut the power off just when you need it most.
So, whilst I agree and was going to get the dealer to change the wheels until I realised the 22's would probably sell for more than a set of 20's on E Laughing bay - there is a possible advantage of having stupidly low profile tyres on an L322.
Ok - so I'm clutching at straws but it's a nice car!
Post #271323 16th Jul 2014 9:51pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
See there's a new 19" option for the 15MY.
Post #271327 16th Jul 2014 9:57pm
3500kg on my 19's - UK to Switzerland.
3500kg on my 18's - UK to Switzerland.
And your three axle trailer will be a much better, more stable trailer than mine.
Post #271328 16th Jul 2014 10:09pm
TugRR
^ That trailer is a MONSTER Shocked , but I bet it tows nicely ?
Not sure it would be legal in the UK. . .
FF looks excellent towing it !
Low profile tyres on FF = nonsense
Thumbs Up Where do you go after one of these . . . ?
Post #271329 16th Jul 2014 10:13pm
It is a monster, but it's not a great trailer. The weight is too high and it's very limited for nose weight (100kg). The good thing is it's only 209cm wide.
Why would it not be legal in the UK, because it's less than 7m long (the bed is 5m long)?
Post #271331 16th Jul 2014 10:17pm
Have you learnt to reverse it yet David Whistle Whistle Whistle
Post #271336 16th Jul 2014 11:07pm
Who says 22's don't work? Whistle
Post #271337 16th Jul 2014 11:09pm
Post #271338 16th Jul 2014 11:11pm
TugRR
^^^ Under seven metres ? - looks ok, then . . .
Seriously though - why that length ?
I get your point on the high centre of gravity - it makes checking your tyres pretty important -
Post #271339 16th Jul 2014 11:13pm
Whistle
Post #271340 16th Jul 2014 11:15pm
Why get an inadaquate one? On several occassions I've used all of it, as you can see from the pics.
Post #271341 16th Jul 2014 11:18pm
Bow down Thumbs Up
Post #271347 16th Jul 2014 11:54pm
While I'm not the greatest reverser, I can reverse it, I just didn't want to reverse it past your cars, house, wife, kids, dog, cat and up your narrow and twisty back passage. Wink
Post #271351 17th Jul 2014 12:00am
RiccartonRR
Kurt - you're correct in that the tri-axle is very stable (and only 4.25m bed length) but that is part of the problem.
Towing the trailer behind my defender fully loaded in a timber yard I had a moment when the car turned but the trailer didn
't want to and simply pushed the back end of the car around. Luckily it was below 5mph but I did go some distance on full opposite lock before it stopped.
The 22s will most likely go but I do like the look of the Disco with them on!!!!
Post #271358 17th Jul 2014 6:53am
Shocked Ill have you know my back passage is not twisty! A little kinky maybe Whistle but certainly not twisty sir! Laughing Oh, and with such a big rig... Rather tight! Shocked
Post #271362 17th Jul 2014 7:49am
Page 3 of 5 <12345>
