Home > General > Got an hour to kill!
Page 3 of 3 <123
Funny that it's covered exactly the same distance.
Post #271311 16th Jul 2014 9:29pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Maybe irrelevant but do you think 4500 miles in a year could be a factor ? Thumbs Up
Post #271312 16th Jul 2014 9:29pm
dhallworth
I did wonder but the less you use a starter motor the better it should be in theory.
The silver TDV8 we had did slightly less mileage, it was sold at 5 years old and had never missed a beat.
I think it might be a couple of hundred miles of a difference but it's certainly not much.
Post #271332 16th Jul 2014 10:22pm
johnboyairey
I don't have the tdv8, BUT I sometimes get a silent no start, no click, and I sometimes thump the selector shaft a little and it then fires, maybe your selector shaft (gearstick) is not correctly 'perking', thus signalling the starter to not energise.... or 'go' ?
Post #271352 17th Jul 2014 12:35am
Big Boy R44ROV
Had a similar problem when I had my RRS SC. Quick tap with a hammer on the casing and it turned over straight away. Was fine afterwards and never had a problem again Tony
You're always in the Censored ........it's just the depth that varies
2014 L494 5.0 S/C AB Silver
2014 L494 3.0 HSE in Chilli
2014 SL63 AMG White
Gone:
2011 5.0 L322 White (Stolen)
07 4.2 SC in silver.
06 4.2 SC in black RSE
RRS 4.2 SC in Black RSE
52 4.4 Vogue in silver
04 Mercedes CLK 320 Conv
03 4.0 V8 ES Disco in Silver
00 TD5 90 County
98 4.6 HSE in Epsom x3
97 3.9ES Disco
93 L 4.2 LSE in black
too many classics to mention !
Post #271369 17th Jul 2014 8:48am
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
We have a 2003 4.4 V8 (BMW Engine) and the starter motor failed last year. As far as we know it was on its original starter so it would have failed at around 100K
Post #271372 17th Jul 2014 9:14am
Googsy
David you have too many cars. I will happily put the mileage up on your TDV8 for you. Cool Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #271411 17th Jul 2014 11:54am
Sandyt
Interestingly I had an intermittent starter problem and it was the lead from the battery to the starter had internal corrosion so it had obviously been left lying around for ages before use the thing was it looked brand new but wasn't till I shoved a meter over it and got some wacky readings that I found the issue
Post #271414 17th Jul 2014 12:09pm
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
My old 2010 L322 needed a new starter at 30000 miles / 3.5 years. Intermittant starting was the symptom. Definite weak spot.
Post #271452 17th Jul 2014 5:47pm
Rosco
As per @PaulTyrer, I am on 118K with original starter motor, maybe they changed spec or extra gizmos are killing them? Food for thought Thumbs Up (Guarantee I wont start in the morning Rolling with laughter )
Post #271455 17th Jul 2014 5:58pm
johnboyairey
as per youtube, starter motors explained, you have the pre-engaged type. looking at your motor assembly, the smaller barrel shaped item, on the starter is the solenoid, this can get a high resistance across it, therefore it is clicking 'in' and not transferring high current to the motor, ie the action is engaging, but not powering the bigger barrel, the motor. and no start. if you are handy, you can dismantle the solenoid and file the contacts clean. you can test the motor first with a positive jump lead DIRECT to the motor terminal. it will spark and make you jump though. this will only spin the motor freely, not turn engine. remember the solenoid will 'engage' this on it's 'action'.
Post #272054 21st Jul 2014 2:39pm
dhallworth
If it were any of the other cars I'd have it off, strip it, clean it and rebuild it but that's what the warranty is for on this one Whistle
Still haven't rang the dealer actually. Will need to get it booked in. It still only does it first thing in the morning for 3 or 4 clicks then starts. Might get LR Assistance out to prove I'm not imagining it before it goes to the dealer as if I drive it there and it doesn't click they'll say they found no fault and send it home again.
Post #272087 21st Jul 2014 6:25pm
Page 3 of 3 <123
