![]() | Home > In Car Electronics (L322) > HSE stereo upgrade, best option ? |
| Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204
Mines had one for 18 months no problems tbh, just time consuming to fit but easy fit if your into electrics or stereo fittings, I've done fittings for years and this ones not hard, there's some on fleabay for 350 ish now, you need to add a tv tuner and dab as mines analogue but some are digital you can buy, your not getting a top bang and olufson but me as a duffer it's fine and looks good, USB and all the bits are fine, I've pics in my gallery, I've got three sat nav cards to use depending on mood, be on road is good and cheap and I use primo 8 , it came with polnav. _____________________________________________________
| RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932
Within reason, speakers are more important to sound quality once you're over a minimum threshold. If the head unit is decent and compatible, there's no excuse not to sound great. |
| Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2723
Upgraded mine a couple of years back to a pioneer double din unit, iphone 5 connectivity, Bluetooth streaming DVD playback, + hands free kit. Ball ache of a job, but so much better, just need upgraded speakers now.. |
| andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 982
is there any option here to get get DAB radio as an upgrade? |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
if you mean changing the radio tuner to a dab enabled one then no ..the newer 2009 onward FF's with dab as standard used a different MOST than the MOST on the 2005-2009 FF's.. ... - .- -.
| Paulmeds Member Since: 18 Mar 2014 Location: Devon Posts: 34
Hi, have been out today looking at double din units instead of the Chinese plug play. They look much better quality more expensive but worth it I think. Has any body got a link to the facia plate needed for double din on my HSE non sat nav ? Also has anybody that has done this found any major headaches that make it not worth doing ? Thanks |
| crakhabit Member Since: 11 Jul 2014 Location: London Posts: 7
I've been looking at the andrive system (http://www.andrive.co.uk).
Facia plate for a BM 5 series e39, toughest part is making room for the headunit to fit. The installer who did mine used a soldering iron to remove enough of the plastic as the existing units aren't that deep.you will also need a piece of ply to bring the unit forward so it fits the facia plate. The guy didn't do this to mine and it would have looked better had he done so. Happy to post pics , but am away for a couple of nights , had to borrow my old dears crv as the ff is waiting on a new alternator! |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000
These may help a bit perhaps ;
Thanks for all the replies. Sounds like double din can be done but needs a bit more work & a good fitter !!
| don Member Since: 26 Oct 2013 Location: plymouth devon Posts: 2
Try google Incartec they are in Exeter they had all I needed to fit a kenwood radio and DVD in my 04 Ff hope this helps don |
There's this one as well on the bay
hi, thanks for everybodys help, but I am still undecided !!! spoke andrive today and there unit is a straight plug play no facia required and with DAB cost about £750-£800 plus fitting. For the same money I could get a double din pioneer, kenwood etc with similar functions just no digital tv and more hassle fitting but these are proven units.
Well I think I am going to bit the bullet and go for the andrive e39 with DAB module added. Looks very versatile with android system and as it is plug play I am told no facia, dash cutting etc is needed. So before I blow £800 and find a fitter I trust to install it has anybody got any advice or experience I could make use of ? |
