![]() | Home > Technical (L322) > Servotronic Valve / Hydraulic Transducer |
Yes post amended! |
KARMANN Member Since: 13 Dec 2010 Location: Scotland Posts: 95 ![]() ![]() |
What's the part number for the filter and the servotronic valve for a 02plate 4.4v8?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35827 ![]() ![]() |
QFW500040 ... - .- -.
SO3isme Member Since: 18 May 2014 Location: Woking Posts: 110 ![]() ![]() ![]() |
Can the valve be removed with just the road wheel off, or does it require putting the car on a ramp? |
just remove the off side front wheel... ... - .- -.
tomthevet Member Since: 14 Jan 2012 Location: Scotland Posts: 283 ![]() ![]() ![]() |
I have the usual problem of intermittent heavy steering which seems to feel like a badly lubed cv joint as you can sort of turn the wheel 'through' the hard part and then its fine til you turn it back.
Last one I did was the power steering pump itself. |
