Home > Technical (L322) > Does a new instrument cluster need programming to the car?
birchyman71
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Just a quick question , someone might know the answer, if I get a brand new instrument cluster ( speedo etc) will it need programming to the car before it works ? Or are they just plug in and use?
Post #272849 26th Jul 2014 1:29am
I don't know but are they expensive and is it hard to replace ? 2008 MY Supercharged
Post #272852 26th Jul 2014 3:29am
adigorn
Yes it does
Post #272855 26th Jul 2014 5:49am
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
If its the hole assembly, speedo , rev counter etc then yes, if just the ribbon for the pixles then no. If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #272856 26th Jul 2014 6:31am
Yes it has to be programmed with your VIN, and cannot be re-programmed into another car (i.e. they have no second hand value... Forum members take note Thumbs Up )
Post #272857 26th Jul 2014 6:46am
87RJD
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Hi all, I bought a second hand one for my 02 TD6, and it worked fine, displayed mileage was from the car it came from, otherwise was fine, I found it straight forward to fit.
Post #272867 26th Jul 2014 8:42am
Nickatvirgin
Hi All,
On the same thread, I have just bought a new speedo cluster for my 2004 vogue how do i get it programmed to my VIN???
regards
Nick
Post #283909 1st Oct 2014 1:58pm
