![]() | Home > Technical (L405) > Knocking noise |
lucky Member Since: 18 Apr 2014 Location: colchester Posts: 87 ![]() ![]() ![]() |
thanks ! I will keep the faith !! |
Sb Member Since: 18 Sep 2013 Location: Leeds Posts: 33 ![]() ![]() ![]() |
Guess what!! ITS BACK. AAAAHHHHH |
stuempf Member Since: 02 May 2013 Location: Frankfurt am Main Posts: 19 ![]() ![]() ![]() |
any updates to this ? did they fixed it ?
tboner001 Member Since: 22 Jan 2011 Location: Bucks Posts: 691 ![]() ![]() ![]() |
Yes the fix is i was told sell the car, i have done with my l494, now i do not hear it knocking , or the trim rattles |
Java Jungle Member Since: 22 Mar 2010 Location: Monte-Carlo Posts: 420 ![]() ![]() ![]() |
goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196 ![]() ![]() ![]() |
my 4.4 Td My2011 had to go in to sort out tail gate issue.
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2621 ![]() ![]() |
The aesthetic appeal is one of the few things that hasn't improved. |
The car is miles apart from my older L322's and it is a totally different drive you cannot really even compare IMO.
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
^ I'm really pleased to hear it. I like to think progress is going forward and JLR isn't going to be in good shape if they're not making good cars.
fairwx Member Since: 10 Nov 2011 Location: bristol Posts: 124 ![]() ![]() |
in response to campaj1 - yes my TDV6 did (probably still does) have a knock, and the senior tech in Guy Salmon Bristol was stumped.
replaced the car or suspension bits? 2011 4.4 TdV8 Nara Bronze |
tdv6 does not have active ARB or ARC !
Tesh14 Member Since: 29 Apr 2014 Location: Kent Posts: 1 ![]() ![]() ![]() |
I have a 2013 SDV8 vogue which has been in for the past three weeks at the dealership. After having two new ARC valve blocks fitted the knocking noise has stopped but now i have bad rubbing noise when i am turning right. I have been in dialogs with Customer service who have now told me that this is just a characteristic of the car, even though it was not there previous to their fix. Can anybody shed some light on what this noise maybe? |
rocksteadyeddie Member Since: 15 Jan 2010 Location: London Posts: 38 ![]() |
Does any one have the part number of the replacement valve block and (ideally) a 'how to' guide to change? Alternatively any idea how much the book labour time is? Many thanks |
