![]() | Home > Technical (L322) > 4.4 bmw cooling system issues.. And yes, i have a 140 cap... |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
Sounds like an airlock to me, think you'll have to take it for a few runs to work it out the system... could also be that the auxiliary pump doesn't work. Pete
| James4287 Member Since: 08 Jun 2014 Location: Cornwall Posts: 20
Under what conditions should the aux water pump work? |
Ive checked voltage down there and have 12v with ignition on but no sound from pump. So ive just ordered one from ebay.. thanks for that i didnt realise there was a pump there... |
Can't promise that will fix it, mine doesn't work either but I don't have your symptoms.... they do like air in the system though and it needs driving to get it out... well mine did.... Pete
| Winchester101 Member Since: 13 Jun 2013 Location: Essex Posts: 236
Mine was holding pressure turned out to head gasket how did you check it 1994 softail full stars n stripes custom harley davidson |
I've checked it using an exhaust emissions tester with the probe over the expansion tank with the cap of and engine warm raising the revs to 2500 revs. The idea being if co or hc was present in vapour from coolant tank I would get a reading on the screen. Which I didn't it stayed at 0.00
| fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1561
Filling the system is best done very slowly. I think a long time ago I put my way of filling it on here and it worked well for me. The process of filling from dry is important to get right and having it overfilled at the tank does not equate to easily getting rid of air locks I found.
Sorry, didn't see your question, actually haven't a clue what cap I have, I have taken the thermostat off and junked it's innards as they just set it to running too hot, It now runs cooler...
| PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263
If you are just topping it up with water then the SG of the coolant will change, and I believe there are sensors that check the SG of the coolant, this may be why you are getting the 'Check Coolant Level' warning as it thinks it has insufficient coolant. |
There isn't any such device on our old Rangies, mine had neat water in it when I got it and I had no warnings up... Pete
Mine is a 2003 BMW engined one and as far as I know it has this SG device fitted. |
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470
Yer they have an SG probe in the tank. That will give a false check coolant message. The heater controls shluld be set to max hot before draining the coolant system to aid refilling. Someone on.here mentioned using a 2l coke bottle upside down to keep it toppednup and a few good revs to push the air out using the water pump. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
| gg2201 Member Since: 21 Oct 2013 Location: Callington Posts: 158
To be fair BMW can't build an engine that can hold water for any length of time and they are also prone to air locks a lot of the straight 6 engines are a pig to get the air out. As much as I curse our Range Rover the only thing that has ever gone wrong on it are the BMW parts..... Says a lot really |
