![]() | Home > Maintenance & Mods (L322) > Rear wheel arch rust a warning |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16353 ![]() ![]() ![]() |
2003 |
andy180 Member Since: 26 Aug 2010 Location: scotland Posts: 509 ![]() ![]() ![]() |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6800 ![]() ![]() ![]() |
Wow! That's scary! |
birchyman71 Member Since: 19 Feb 2013 Location: stockton on tees Posts: 147 ![]() ![]() ![]() |
Yep. Looking into what to do , wether I weld it up my self ( not my first choice as I'm not a great welder ) or give it to somebody to cut all the crap out then weld new metal in then I'll paint it and put all the trim back . Will start seeing about quotes tomorrow .! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8670 ![]() ![]() ![]() |
Right next to the plastic petrol tank as well.....
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
see my motto below... V |
Had it into a bodyshop today for a look £250 - £300 for both sides sorted out so it'll be going to be done in a few weeks . |
Finally sorted this out did it myself in the end borrowed a mates mig welder and plated the hole then treated all with kurust then filled painted and polished the bits you see and stone chipped the bits behind the plastic , also repainted the wheel arch lip and got a plastic protector strip for it , now got the front subframe to go at where the powder coating is coming off .
Nice job there, should give you a few more years....
I'll post some before and after pics of the other side tomorrow as I'm painting it if the weathers ok , it's nowhere near as bad no major holes just a lot of surface pitting from the rust |
Super job there mate. Weldone. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Tidy |
