![]() | Home > Maintenance & Mods (L322) > air suspension inactive message |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35832 ![]() ![]() |
a faulty/damaged abs brake sensor cable together with low brake fluid might cause this ..i'd check the sensor cable first .. ... - .- -.
Yes, as stan says, any brake fault will cause the air suspension to deactivate for "safety" reasons. Sort out your brakes, problem will go away, but you may need to clear the fault. .
kiter Member Since: 04 Jan 2013 Location: Inverness Posts: 182 ![]() ![]() |
Thanks guys - see how I go once the brakes properly bled, get that done tomorrow night hopefully. |
All sorted after brakes bled and all is good again, probably not for long..................! |
