Home > Technical (L322) > Rear fuse board |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34962 |
i dont think all are live all the time, some might shut down after about 15 minutes .. ... - .- -.
30th Jul 2014 9:50pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1898 |
Hmmm ok Stan , I will pull them out one by one over time to see which is ignition live, but 15 min seem a bit too long for what I need it too do. All be reviled as soon as whats it for. If it dont work.......burn it!
30th Jul 2014 9:56pm |
its just a guess mind.....its very easy to run a feed from an ignition live from the front as you have probably discovered.. ... - .- -.
30th Jul 2014 9:59pm |
30th Jul 2014 10:01pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 |
There is an ignition live in the rear fuseboard area, not on the board itself. It's a 0.5mm2 green / yellow wire which serves the rear tow socket, it's the only ignition controlled feed in the rear compartment. It's fed from fuse 2, 5A on the passenger compartment fuse board at the front.
30th Jul 2014 10:10pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6400 |
There is an "ignition live" on the other (left) side at the rear as well (in with all the AV gubbins)
30th Jul 2014 10:22pm |
Thanks guys I will have a look tomorrow, that will save a lot of hassle feeding a wire from the front. If it dont work.......burn it!
30th Jul 2014 10:32pm |
markcartlidge Member Since: 18 Mar 2013 Location: Nr Winslow, Buckinghamshire Posts: 120 |
Hi Guys,
14th Jan 2018 4:05pm |
