Home > Technical (L322) > 2004 AC Icing up after a while... |
Just wondered if anyone else had experienced their AC performance dropping off over time, oddly it seems the hotter it is outside the worse the problem...
27th Jul 2014 9:33am |
corinthian99 Member Since: 02 May 2014 Location: Hitchin Posts: 37 |
Low gas pressure in the evaporator could will cause frosting as will a defective DXV valve. Low gas will also cause underperformance. Most systems will lose gas over a prolonged time which will eventually reach a point where the cycle ceases to work.
27th Jul 2014 10:25am |
Thanks - I've ordered an evaporator temp sensor as that's the easiest thing to test at the mo. I live in Cornwall - Air Conditioning is seen as the devils work. I have to drive over an hour into Devon before I can even come across the likes of a kwikfit - let alone an AC Specialist!
27th Jul 2014 10:17pm |
Ah, its about the pressures - I won't bore you with it. Anyway good luck, bit upset by your post as I'm about to start a 8 month job at Pendennis Shipyard in Falmouth, facilities that bad down there? Already not relishing the prospect of the drive every weekend in a 4.4L |
28th Jul 2014 9:39am |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 |
Looking at your picture, it's a serious problem - it's causing the world to ice up. |
28th Jul 2014 5:21pm |
666tur Member Since: 15 Feb 2013 Location: Nottingham Posts: 108 |
I say straight forward. I was wrong. Looks a pig, stripping half the dash out. All to change a £25 part.
5th Aug 2014 8:40pm |
A know it all friend suggest I try to rule out a leak in the system. I bought a £2 UV torch from ebay and found a leak in the bottom left hand corner of the condenser.
3rd Mar 2015 11:42pm |
