![]() | Home > For Sale & Wanted > [Swap] My MY10+ Cherry Wood interior trim for a Black or Dar |
Best painting it or dipping. Wrapping looks good but you will have orange peel finish and eventually you will remove and paint anyway |
You probably don't travel quite far enough for me , do you also have the pieces on the rear centre console ? not sure if all cars have them and some pieces are right number to remove if I remember . 2008 MY Supercharged
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8064 ![]() ![]() ![]() |
I had mine removed, lacquered black & re-fitted - they are identical to the factory ones - and 3 years on, look as good as new
milesg Member Since: 18 Dec 2013 Location: Gloucestershire Posts: 120 ![]() ![]() ![]() |
Sorry Axle, I don't travel that far.... But with it being th SE I do have the rear console bits too...!
Pics of rear....
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
We can assist you if you require it all removing (for paint etc) could probably sourse you some Piano too...
Hi Craig, May well be seeing you soon. Can they be removed so the car can still be driven whilst it's painted?! |
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 972 ![]() ![]() ![]() |
hi craig, hope you are well mate
Not really as to remove the nav cheeks you need to remove the top of the dash, disabling the airbag system... To put it back together to be driven, then re-installed would be twice the labour! ![]() |
