![]() | Home > Technical (L322) > Fitted new compressor and fault still showing up. |
| 87RJD Member Since: 01 Dec 2013 Location: Wokingham Posts: 103
Is the compressor you've fitted new, second-hand or refurb? |
| rich89 Member Since: 05 May 2013 Location: United Kingdom Posts: 295
Brand new from duck worth. |
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1883
Corroded/Leaking reservoir? |
| Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700
I had a split in an air hose giving the same error. It was behind the offside rear wheel as the pipe comes out of the wheel well. If its taking too long to lift the car, the air must be going somewhere, so it should be possible to hear if you have a leak.
Doesn't seem to be leaking anywhere. I will check tomorrow again just incase the new compressor has pumped it up abit more than the old one.
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
What is the fault: as read by diagnostics ? .
Before I fitted the compressor it was, reservoir too slow to fill up. code was C2A160 or something like that.
