![]() | Home > Technical (L322) > Suspension vibration only in right hand corners |
| Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2591
Anybody....... |
| RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724
Hmmm - personally I'd give it a good coat of looking at before driving it any further. In particular check your steering arm ball joint and wish bone ball joint / bushes.
| Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700
100% lower suspension arm... Common problem. It only did it to me on long sweeping corners at speed. It can give quite a shake/knock.
Cheers guys, was worried it may be something I hadn't heard of |
| trainmanone Member Since: 26 Jul 2012 Location: stockport Posts: 201
did you get this sorted I have similar on left hand bends at 50-60 mph
It was the lower suspension arms on mine, had both changed and all sorted, |
thanks will do n/s one just had o/s done have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
had them done still the same but now on the straight have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
I would suggest that if it is now doing it on the straight and it wasn't before the work was carried out, then it's not been done properly... Has it been tightened up correctly? Is it tight? Previously..
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
Check with the Mecanic if he tightened the main through bolt on the ground or with the car in the air.
