Home > Technical (L322) > Pressure release valve MAV 500010.
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
@Joe90, did you get to the bottom of the fault code 74, I get this one a few time of late, all seem well with the suspension though. If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #270665 13th Jul 2014 10:40pm
Not yet, have temporarily setup a workaround of fixing the EAS in Motorway height.
When I get a moment, planning on stripping down the valve block on the reservoir and checking if the reservoir is full of water. if the one way valve in the valve block is stuck I may be able to get it going again.
2nd hand valve blocks (with no guarantee they are any better than mine) are @ £180 so this is worth a shot. .
Post #270672 13th Jul 2014 11:19pm
So after the last fault, I reset all faults.
Is this a temperature issue? (reservoir pressure static when filling)
Today, temp outside was @ 14 degrees, no fault registered on drive to work. Coldest it has been for several weeks.
Bet it faults on the way home once it has warmed up!
Oh, and when it does fault, there is no "bong" just message display....
No fault when taken out for lunch (24 degrees)
No fault on the way home (24 degrees)
Is it something else (another fault) causing the EAS to fault? Next time I'll run through all the ECUs as opposed to just clearing the lot... .
Post #274357 5th Aug 2014 8:24am
Welshdragon
Very interested in what you find Tim. I did a long run over the weekend with no issues with the ff and the eas, low and behold coming home tonight, message on display, NO bong, I rest and went home, as soon as I turned ignition off bong message up as before, I restarted and did the lock to lock and turned her off, all ok.......till next time Whistle
Now do you when you have reset with tool and cleared fault ( mine is 74 fault also) do the lock to lock on the steering?
I have not done the prv yet though. If it dont work.......burn it!
Post #274583 5th Aug 2014 11:08pm
Forgot to mention I put the relief valve back on!
Not been doing any lock to lock work after resetting with IIDTool, not needed afaik... .
Post #274593 6th Aug 2014 12:39am
After two days of behaving faulted again today in the morning.
Read full fault code list from all ECUs
Quote:
ABS Anti Lock Brakes None
ARM Airbag None
AIR/COOL 0x2F Aspirator Motor Fault (old friend)
0x30 Air Quality Sensor Fault (new one, not seen that before)
BPM Body Processing None
DSM Seat None
EAS Suspension 0x74 Reservoir Pressure Static When Filling
ECM Engine 0x3505 Unknown(old friend)
0x0404 Unknown(old friend)
FBH Fuel Burning None
HID Left HLight None
HID Right HLight None
IP Instrument Pack None
LCM Light Ctrl V11 0x57 Air Suspension Active/Inactive
0x8E Right Side Marker Defective(old friend)
0x8F Left Side Marker Defective(old friend)
0x0094 Unknown(old friend)
0x0095 Unknown(old friend)
PAM Parking None
PATS Antitheft None
RAIN Sensor None
SASM Steering Angle None
SCLM Steering Lock None
TBOX Transfer Box None
TCM Transmission None
Nothing there I can see that might make it chuck a fault other than the LCM one, but I am guessing this fires after the EAS faults. .
Post #274837 7th Aug 2014 5:59pm
netsonic Steve
United Kingdom 2002 Range Rover Vogue Td6 Epsom Green
Joe have you replaced the pressure sensor in the air reservoir
Post #275307 11th Aug 2014 12:10pm
Welshdragon
I had seen somwhere that pressure switch can be problematic, but which is more likely, switch, compressor pump, valve block.....all 3 ! Big Cry Big Cry
I my case its not the PRV as I have by passed it and getting the same fault code time after time. Code 57 in the LCM and code 74 in eas. If it dont work.......burn it!
Post #275373 11th Aug 2014 6:29pm
