![]() | Home > Maintenance & Mods (L322) > Air con condenser removal |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Arrived today, did the swap over this evening. No real dramas. Existing condenser was also a replacement, not LR, appears to have "gone" in the same place as the OP. Also that corner seems to be a leaf and bug magnet, so took some time to clean out this and the opposite corner, scraping with a wire coat hanger and vacuuming out. I removed the electric fan cover for better access.
| steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356
Well you set me off condenser ordered to day and will be here on the 7th so swap it over soon as i get it and hope to be cool |
Did the swap today at my garage, got the car bonnet up at 9.00am and had this post up ready just finished and put all the tools away great post and a fantastic help why did i wait a year to do the job |
| Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35878
..and no screws/bolts left over? ... - .- -.
no bits left LOL and had her gassed up and cold as a fridge |
Gassed up today. Brrrrrrrr!!! .
Got frost bite Tim |
| johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035
i did mine a while back as I was changing the water pump, and took the water rad out, therefore not removing the slam panel. grill was off from memory. no dramas, but those union bolts, sure are tight. give em a soaking, and another just before you turn em. I think I had to get some moles on one...I had to change out my pump too at same time, (about £250 online) so water rad out as necessary. -only three bolts. jobs still a good-un.
| 666tur Member Since: 15 Feb 2013 Location: Nottingham Posts: 108
I have been having air con problems. Bought a UV torch and discover bright green dye on the bottom corner of the condenser. Going to replace thanks to this handy DIY. Did you use any special air con oil on the o rings? 2012 4.4TDV8 VSE
Nope just a good lick |
Thanks Welshdragon. What am I pulling up? The aluminium air con pipes that connect to the condenser?
The drier should be included/built in to the condenser - other end to the connections - white plastic six sided plug. If you tilt the new/old unit you should hear a clunk. .
| All times are GMT |
