![]() | Home > Technical (L322) > Turbo squeal STILL. Help save my RR because I'm done :( |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
Hi SteveyD - FFs were born to frustrate us but hang in there.
SteveyD Member Since: 11 Dec 2012 Location: Cheshire Posts: 352 ![]() ![]() ![]() |
They certainly do! I should put a grinder straight through this ones heart!
Hi, Sorry - what I meant was the hose from the turbo to the intercooler.If it is a leak somewhere up stream which only occurs during boost then this should prove it. Just bear in mind that your turbo will be blowing plenty of air around the place and your tail pipes will blow black!!!!!
Ah good point, I have had the hose disconnected just before it enters the intercooler and all was fine, great turbo noise was also produced |
Good luck!
chris595959 Member Since: 09 Jan 2012 Location: Brighton Posts: 71 ![]() ![]() |
Cracked exhaust manifold i bet |
Sorry should have also added possible head to exhaust manifold gasket failure |
cowman Member Since: 24 Jul 2013 Location: United Kingdom Posts: 186 ![]() ![]() ![]() |
hi,i have got the same problem as you and mine is driving me mad as well ,changed my turbo ,no different,i have a blanking kit on mine and on monday was going to put the old egr back on ,i just ran it on tick over and squirted some soapy water around the joints to the egr valve and the joint with the stainless clip was bubbleing so i thought i had found the prob resealed it but still there maybe not as bad maybe me just being hopeful. |
Interesting, I'm away now for 2 weeks and the car is in for paint. If you wouldn't mind refitting your EGR and posting the results that would be a big help.
Back to the EGR leak, I have seen recommendations to use exhaust putty to create a better seal.
changed back to egr today took it for a spin no different noise still there under boost,fed up now again ,back to the drawing board. |
I feared that would be the case, logically there is no reason why EGR removal would cause VNT issues, if anything it should help the turbo to run cleaner as there is no 2nd cycle gasses being pushed through it.
i have replaced the inlet manifold senser ,new turbo 3 weeks ago,changed the vacuum senserso dont know at the moment |
Even the new turbo could be faulty... It happens but obviously highly unlikely. drive the car, at about 30-40 mph hit the throttle pedal on off on off on off on off throughout the rev range, that made my vnt squeal vanish until the following day, hence my thoughts on re-visiting vacuum and pressure sensors. |
