![]() | Home > Technical (L322) > Cooled/ventilated seats |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35685 ![]() ![]() |
you dont get a significant amount of air coming from the seats but enough to cool you down...have you got the 'back' and 'seat' lights lit on the control knob.. ... - .- -.
@CB, ours has cooled/heated seats and for sure the seat/bottom parts of the seat benefit from the strongest cooling and heating aspect and because the seat bottoms perform so strongly, it can indeed seem like the back parts don't work quite as strongly. I'm sure I've read on the forum before that this is just how they perform and it has never bothered me because both parts do work.
countryboy Member Since: 05 Aug 2014 Location: Reading Posts: 37 ![]() ![]() |
Yes, the lights are on and fan appears to be working..! |
Great, it's not just mine then! Yes the driver's side is so much more powerful than the passenger's side. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16342 ![]() ![]() ![]() |
There are serviceable filters on all four blower motors... Worth changing them first!
the filters are an interesting point craig, are they easy to 'look' at.. ... - .- -.
There are one under each seat and one inside the rear removable (hard back) cover Stan... The ones under the seats are easy to view... |
Good shout, how does one remove the back of the seat, I can't see anything obvious and don't want to break it..! |
@cb, if not your filters as mentioned by CTC, this linked thread will take your OP to a whole new element... Ahem |
Cheers chaps, I'll keep you posted! |
